I have a 1994 Mariner 90HP 3cyc 2cycle, oil injected outboard engine.<br /><br />My boat won't start. It was running fine last summer. When I tried to start it today, the engine would barely rotate, as if my battery was dead. So I assumed it was the battery and I tried jumping it off my truck, no luck same thing. So today I bought a new battery which was 550 marine CC amps. It seems to rotate a bit faster, but nothing like when it should when it cranks normal. So I thought maybe the battery wasn't fully charged from the store, so I charged the battery at 6amps for about an hour till it was full, same result. I am currently charging it at 2amps and will try again.<br /><br />My first questions is: Can you jump a boat off of a car?<br /><br />Second: What else could it be? Do I need a bigger battery?<br /><br />Items recently repaired were a new key ignition because we lost the keys, and a new vertical shaft. I'm assuming its the drive shaft not the prop shaft. If anything was wrong with the installation, I feel the engine would not rotate at all, not just sound like the battery was not charged. The boat hasn't run since these repairs, just because this was done over the winter time and no one wanted to start it in the cold.<br />
<br /><br />Any help would be great!<br />Thanks<br />Bryan
