"94 MCM 5.7lx vs 350 Magnum
QC
Re: "94 MCM 5.7lx vs 350 Magnum
MPI vs. carb and I think roller lifters and the cam to match . . .
I'm Not Sure,...... And,.. I'm Not going to spend the Hours needed to research the Parts Books,......<br /><br />But,...... I Think this is the point where you go from "Standard Production Marine Engines" to High Performance Engines,....<br />Where there are No Doubt some Stronger Parts are used in the Build-up......<br />Maybe stronger Pistons,... or Hotter Cam,... Or Possibly a Forged Crank,.......<br /><br />BTW,..... This is All, Purely Speculation on My part.........
John_S
Last year, I looked at the online parts look-up sites, Merc Service manuals, and Dennis Moore's SBC Perf book, researching the differences between the 5.7L and 350 carbed mag. <br /><br />Whie I wasn't looking at the LX specificly, from what I remember the intake manifold is the major difference. Carb jetting/rods might be slightly different, and the advance curve might be different too. I don,t remember the year Merc switched from Q-jet to Weber, but if weber in '94, the LX would of had a squarebore to qjet conversion plate. If the LX has 97XX weber carb, it is a 750cfm, like the 350 mag. The 96XX is the 600/625cfm weber.<br /><br />As far as I know, there is no gurrantee if you have roller or flat hydraulic lifters, without looking. There was only one flat lifter cam and one roller lifter cam, during the late 80's/early 90's. Both were used in the 350 mag, in the late 80's/early 90's. <br /><br />Accordingto DM's book and what I was able to check in part numbers, there wasn't any differences on the pistons, rods, crank, etc. No 4-bolt mains in the mags, either.
