I have a 94, 90 hp, 3-cyl. Mercury. It runs great except that it boggs down accelerating from stop. If the throttle is advanced very slowly it does Ok. If throttle is slamed, the motor dies or if you pull back quick enough, it will catch back up at idle. It idles good and runs good at all speeds once you get past the bog point. I have rebuilt the fuel pump, but was having the problem before. I have replace dthe plugs, fuel line and bulb and run two tanks with Seafoam thru the motor. I have had the boat for two years. The bogging problem started a couple of months after I bought the boat. Any advice would be appreciated. Thanks.
