94 mercrusier 4.3 alpha one.... I think its called a steering actuator...
Just picked up a 94 JC 266 tritoon. From very little research I can find, and what its supposed to have...I believe I have a hydraulic steering actuator? as my steering system.
I noticed it "rocks" back and forth when you move outdrive... and not only does the "piston" side move in and out.... but the side where the cable comes into looks like it is moving in and out as well. Just doesn't seem like that part should be moving that much.... the whole system rocking and the cable side moving as well.
Any ideas on a replacement parts cost or how hard to change.... for a small "sapling" style shade tree mechanic
Ayuh,.... With the motor off, there's abit of slop from the sensor valvin',....
