its plugs are only 3 weeks old and was running great all morning. i shut it down, fished a little and now it wont start. its not getting fire to the plugs from the coil pack. motor turns over fine. what would make it do that with no warning? thanks
Welcome to iboats. It could be anything (stator,trigger,switchbox,rectifier,ignition switch,lanyard switch or short in harness).<br />It becomes a process of elimination, so start with the easy stuff. Remove the black w yellow stripe wire from the switchbox, and see if fire returns. If it does, the problem in in your kill circuit (switches and wire harness).<br />If not, you got a dead switchbox, trigger, or rectifier et al.
