94' mercury problem
Kwaynem
I have a 94 40 HP Mercury and it acts like it has no power when you give it full throttle to take off it don't even raise the bow of the boat up. I pulled the top off and checked it in neutral then put it in full throttle position the bottom is all the way over against the stop and the top linkage doesn't even look like it moved
achris
More fish than mountain goat
The bottom, carburettor? Top linkage, spark advance or carburettor, or something else?
Also, around that era, Merc had a 2 cylinder, a 3 cylinder and a 4 cylinder 40hp... Could we have an engine serial number please?
Chris......
achris
4 cylinder, electric start, long shaft with oil injection... (ELO, not the band :D)
GA_Boater
ELO means Electric start, Long shaft, Oil injection.
ELO means Electric Light Orchestra.
Good one. Chris. LOL
Kwaynem
Lol remember electric light orchestra I guess I'm out of my league on the other lol
Kwaynem
So no suggestions other than dig out my old cassette tape collection?
titaniumneck
Put in a barrel, and timeing light on it make sure timing is advancing. Maybe first check compression on all cylinders. A motor can sound great and not miss, but have no power because one cylinder has no compression. Mine did that, bad compression on top cylinder, luckily it was just blown head gasket.
25xs
I think you have answered your own question... If the carburetors are not BOTH opening / actuating with the throttle, then you have likely broken the black, plastic linkage part between the two carburetors. It is Part No. 53719A2 and found here on iBoats:
http://www.iboats.com/Boat-Parts-Ac...--searched.1--filter.prod_name?q=53719a&s=sol
If you look it up in an exploded parts view, it is NOT found on the page with the carburetor, rather it's in the view of the fuel pump, picture key #30 between the "ghost images" of the two carburetors.
Tom
Kwaynem
Thanks Tom if I checkthe compression a guy told me to pull all spark plugs then turn the motor over with the key and check the guage I did this and each cylinder read 8psi sounds like it's the wrong way to do it
