I have a 1994 Evenrude 200 (60 deg. Loop charged). Bought it used and have always had a hard time starting in the water (but fine on a hose). At first I would get it to the water and flood out the engine. I adjusted the timing and air/fuel mixture (1.5 turns from fully closed) and ran a can of OMC’s engine tune through it. This solved the problem once. Second and subsequent trips to the water would leave me unable to start easily. Usually after 20 minutes and a number of ether shots I could get it running.<br /><br />After initial startup, It has always run great. I read a similar post from history where an incorrect flywheel was installed (for a large looper on a small looper). Not sure exactly what the difference is between loopers. Could this be a problem for me? How do I determine the looper size of my engine and flywheel?<br /><br />Any other ideas?<br /><br />Thanks in advance.
