freetime99
- Sep 11, 2007
- 129
Have had carbs cleaned and rebuilt recently, the bottom cylinder has spark but is not firing until after getting on plane, then engine runs OK. Also have replaced fuel filters and spark plugs. When it's idling, it's rough, sometimes cuts off. You can remove the bottom plug wire and it makes no difference (shows that is the suspect cyl.) Spark chech shows all plugs firing.What would cause just the bottom cyl. not to get fuel at low speeds but run OK at higher rpm's ?
