95, 115 intruder fuel line pressure drops off
arntarchie
MY 95 115 intruders fuel presser falls off after sitting for an hour or so requiring me to pump the fuel bulb to regain presser at which time the engine will start fine. is this normal? if we stop and don't sit to long it will start just fine without a prime.
boobie
Re: 95, 115 intruder fuel line pressure drops off
On some motors this is normal. If it really bothers you, you may want to check for any fuel leaks. Or you may have a bad primer bulb.
bob johnson
most likely a small air leak in one of the many fuel line connections........
one by one step by step.... from the gas tank to the fuel component bracket
bob
