Hello, I've got a 95 Mariner Magnum 40hp 4 cyl. that the overheat alarm goes off after about 5 mins. of idleing. History: I took the boat out about 2 months ago for a 3 mile no wake run and a 1.5 mile w.o.t. run each way, no problem. Last time I took the boat out the alarm came on after the 3 the mile no wake run but the motor was not untouchable (hot) and the tell tale was strong as it always has been (very strong, but very warm). After limping it back to the boat ramp, I decided that the alarm was bad so I replaced the harness (in case of a short) and bought a new key switch with a built in alarm. I had previously replaced the oil sender and the oil module. Also, I bought a Faria temp sender and hooked it up on the exhaust cover (only place I could find). I ran the motor today for about 5 mins and the alarm came on again (steady alarm). The motor is not so hot that I can't touch it for a few seconds and the temp gauge reads 100 degrees. I did test the temp sender with a heat gun so I know it works. I've also found this model motor doesn't have a thermostat, if that is true how does it regulate temperature? The only thing I haven't replaced is the factory temp sender, I'd like to test it but don't know what temperature the alarm should go off at. Any help is appreciated. Thanks, Kyle
