I have a 1995 +- 6 hp that has low compression , 75 PSI on both cylinders. I am unable to get a constant or smooth idle on this engine under load. I have tried all the set up procedures in the book and am unable to get a smooth idle below 900 - 1000 rpm. Under no load it will idle fine<br /><br />I started by re/re the pump, no effect.<br /><br />I had it down to the bearings this spring as it had 60 PSI at that time and would not idle under load for more than 5 minutes, mostly less. Now, under load, I get any where from 5 seconds to half an hour. the longest times are generally when the engine is cool or cold, I use an electric motor to troll most of the time but need the gas motor for windy times. <br /><br />just had the cab apart lst night after talking to a small engine mechanis and still the same performance. <br /><br />Suggestions?<br /><br /> <br /><br />On the advice of a couple of mechanics we did not replace the rings, just buffed the cylinder walls. (there was no obivious glazing and the rings and pistons were all above minimum specs.) this gave us the 15 PSI increase. <br /><br />I saw a previous posting about using water sprayed into the carb to remove carbon, will this little trick work in this situation.
