95 Alpha1 Gen2 cutaway diagram
fat fanny
Any of you fellas have cutaway diagram of the lower unit? Wanting to get a better understanding of the oil passage route from lower to upper before finishing my lower units winter service and mating back up to the upper. Before replacing the seal carrier I noticed a port @ about the 11 oclock position facing aft does this port supply oil to the quad seal port? Any insight would be helpful. Merc manuals don't show this port.
Re: 95 Alpha1 Gen2 cutaway diagram
Ayuh,.... There's only 1 passage 'tween the upper, 'n lower,....
Run a piece of fine wire down the passage, if it come out where yer Lookin', That's It...
fat fanny
As usual Bond-o easy and simple answer Thanx ! But already done that and it does enter the quad passage just being curious to any other ports that aren't visible in plain sight last time I changed fluid it was hard to pump up through the drain hole ( fluid was warm from sitting in the sun).
