Re: 95 crownline 4.3 bad block
Just replace the casting/ freeze plugs with brass ones cheap maybe 5 bucks.
Leave the guts alone.
Of course the flywheel, coupler, got to be changed over, you know the drill.
Fuel pump, alternator, if they were marine ones on the old block, got to be changed over.
Oil pan good on the new one? Paint the heck outta it after you clean it real good.
Heck paint everything when you get it home before you start changing everything and it's stripped down.
For that paint i used rustoleum high heat paint in the shake can. 2 cans will do nicely.
I even paint my starters, 3 -4 times, and the alternator, i tape the screen and paint that good also, but thats me.
Good luck !
