95 dt85 dies in gear
kelpedup
just bought boat went out it ran good 20 min turned it off it started but when i put it in gear it died trolled back changed plugs ranlittle better then same thing waiting on carb kit f/p kit thermostat manual plugs and water seporator filter hope im on right path how do i check throttle sensor waiting on book any advice would be helpful thanks:(:(:eek: where do i find sieral #
D
DJ
Guest
Re: 95 dt85 dies in gear
I assume you are referring to a Suzuki 85. As I recall that is a three cylinder. They will run on two, surprisingly well.
If you have good spark, you have a carb. issue. The Mikuni's on those are VERY sensitive to any debris.
kelpedup
when checking compression do u take all the plugs out or one at a time?:rolleyes:
D
DJ
Guest
All of them. Pull the kill lanyard and make sure it turns over at least five times for each cylinder check.
kelpedup
thank you for your hlep wish parts and book would get here 3 to 4 more days
