Yesterday, while cruising at idle for about 15 min, the engine suddenly bogged down and wanted to die. Was able to keep it running with full throtle and get home. Engine fires perfectly at the click of the key and will rev normally in neutral. But when put in gear under load, has no power. Full throttle will give 5-10 mph and sounds very choked. Throttle response resembled that of fouled plugs on my snowmobile. Have replaced the plugs and added dry gas. Idle may be a little smoother, but no change in power.<br /><br />Any ideas?
