95 evinrude 40hp fuel issue
hautewheeler
Hi everyone.. this is my first post here. I have been reading a lot and enjoying seeing so much wonderful information being shared. - just want to start by saying thanks for that.
- so I have a 1995 (I think) evinrude 40hp electric start tiller motor with a tilt assist cylinder on my 1978 16' monarch alum. (great combination). I don't see an id tag on the transom clamp, but I did go to the bombardier website, deciphered the secret code, and the closest I can figure is that it is a E40TLEOD. the freeze plug on top at the back of the block reads G3998959.
I see a lot of the same posts for fuel issues, and before I got a new fuel pump, I thought I would ask some questions. I'm pretty sure that this motor has the vro, but the previous owner disabled that, and I have always mixed the gas and oil 50:1. the vro pump assembly is still there, but there is no oil line going to the motor.
for about two years the engine has intermittently had the same problem. sometimes it will run fine, idles good for 5-10 minutes at a time, gets to WOT (I learned that today:)) no problem and stays there. other times you have to keep priming the bulb every 1-2 minutes to keep it running. when you prime the bulb, the engine runs great until it loses pressure (I think) and seems like it only runs on one cylinder (bogs real bad) and goes back to running fine if you pump the bulb. Now, it doesn't always do this.. sometimes, it seems like it snaps out of it, and goes back to running fine for a while. recently, it has become more constant. and will now die completely if you don't prime within 20 seconds of the bogging. sometimes it will bog, then kick back and forth high to low rpm, and then usually goes back to bogging.
I have replaced both external fuel tanks, new fuel lines to the engine, new high flow bulbs, made sure all lines inside the cowl are secure, replaced the fuel filter, (the old one was not bad) replaced the fuel fittings to the tank and the motor. I don't see or hear any thing when pressure is applied to the bulb, (no leaks or pinholes) except it sounds like one or both of the carb bowls are filling with fuel. so I am thinking either one of the floats are sticking, or the fuel pump is going. will it come and go, or will the fuel pump just quit and be dead?
I have ordered two carb rebuild kits, and will get them cleaned, rebuilt, assembled and put back on soon as the kits get here. I have never done work on an outboard engine before, but I am pretty good with a wrench, and these don't look anything like a rochester quadrajet!!! It looks like it might be a fairly simple rebuild as long as I don't goof up the linkage.
I have yet to test and see if the vro/fuel pump is working, but if it is found to be bad, can just the fuel side be rebuilt, is this pump covered in the parts from the 433519 rebuild kit? should I do the non vro fuel pump conversion? I know it's a lot of questions, but it seems like you guys are pretty good at these types of things. I hope I gave enough information.
if this goes well, I might be back to talk about getting the "good idle" to the "great idle"
-thanks guys, in advance.
hautewheeler
Re: 95 evinrude 40hp fuel issue
Thanks JB.. I guess that was a bit wordy. I saw all of the common questions, and common replies, and wanted to throw in as much info as I could. the post automatically squashed all of my paragraphs for some reason.
short version, I guess:
Model: 1995 evinrude 40hp tiller electric start, (disabled vro)
Poblem: engine will not run correctly unless primer bulb is squeezed now and then. problem has come and gone over the past couple of years. problem has gotten worse recently.
Questions: are all in the last two paragraphs.
1. does anyone's opinion coincide with mine? (about this being a fuel pump or carb float issue)
2. would a fuel pump slowly go, or be an abrupt expiration?
3. can the fuel side of the vro be rebuilt?
4. are these the parts that I will find in the 433519 and replacement kits?
5. would I be better off replacing the pump with the often recommended non vro pump?
6. I am not a marine mechanic, will the carb rebuild be straightforward? (I did see the great thread in the secret info section).
Things I've already done:
New:
fuel line
high flow bulbs
fuel fiter
fuel tanks
fuel fittings to tank and engine
spark plugs (ql78yc)
Checked:
compression - good
fuel lines inside cowl - tight, no leaks, look to be in great shape
(yes- vent is always open)
line pumps up tight when not running
I think that's everything.
JB
Nice job, HW.
I agree that you probably have a fuel pump problem. You have already eliminated other suspects.
I would use a non-VRO pump.
Good luck. :)
hautewheeler
thanks JB.. I will go and get one on the way right now. after thinking about it, it wouldn't be the floats in the carbs, because if they were stuck down, the engine would be constantly flooding out, and if they were stuck up, they wouldn't allow fuel to be pumped in with the primer, running or not.. I will probably rebuild the carbs anyway, just so I can learn about it!
Thanks again..
hautewheeler
hey .. what do you know... Iboats has that part on sale right now for 44 bucks.. lucky day! thanks again!
