hi and how are you? pls help me out.i have 95 force 120hp and I am working on removing the power head . not the lower unit.
so far I have disconnected all links, remove four bolts inside the cowl or engine bay, and eight nuts from the long stubs under the powerhead after removing the small cowl.
what should I do next to get powerhead lose and remove it. thank you
