95-force-70hp 3cyl. water in cylinder??
shrimpman123
I have the above mentioned engine a 1995 --75 hp force 3 cylinder, with the merc ignition. is this engine one of the force engines that can leak water into the cylinder thru the side intake etc..Im getting water in the top 2 cylinders, but the comp is good, actually all within 2 lbs of the others.but top 2 are very clean almost washed looking,and its skipping. ive pulled the head and cant find any cracks, gasket looked seat good,got a new gasket coming. if that dosent stop the water . where else can it be coming from? also replaced all fuel sources of water ie NEW TANK, filter ,fuel pump rebuild etccc. help me if you can guys.
shrimpman123
Re: 95-force-70hp 3cyl. water in cylinder??
what do you call the rear port side of the engine, the area with all the bolts similar to the head,but rectangle,in shape,looks like one mybe two gaskets involved there?
roscoe
Re: 95-force-75hp 3cyl. water in cylinder??
That would be the exhaust port plate, and the exhaust port cover. Yes, there are several gaskets there.
shrimpman123
can these gaskets fail and cause water in the cylinders?but still have a good compression check?
