I have a 95 Johnson 175, took it out today after changing the plugs to see if it would run smoother. It jump up on plane fast and ran smooth until I hit between 5250-5400 rpm's. It missed a time or two so I came off plane down to an idle and it cut off. It restarted after a minute and we idled around for about 10 minutes, tried it again and we hit around 5500 rpm's and it missed twice in a minute? Thought changing the plugs would do the trick, but is there any advice that you might have before I take it in? Also I was wondering I am running a 19ft. Javelin with this motor. I GPS'd the speed today and we hit 59mph. I am running a 24p Raker, is that normal? Thanks
