95 Johnson 90HP OB Constant Warning Horn
erebus
Hello, I've done alot of searching the threads around here, and can't seem to find a fix for my problem yet, was hoping someone might be able to point me in a direction.
The other day a friend and I were boating around and we stopped to anchor for 30 minutes or so, when I went to turn the key to the on position, the warning horn stayed on for a few minutes, turning the key from off to on several times and the horn finally turned off.
We boated some more and stopped and the horn came on again and I have not been able to get it to stop since. It's just a constant tone.
Unplugging the temp sensors has no effect, If I unplug the wires from the oil tank, tan or black, the horn goes off. The water pump is still working and it doesn't appear to be overheating.
I also notice that the horn has three wires going to it, a black ground, a tan and a purple. If I unplug the tan or the purple the horn goes off.
Anyone have any ideas what I should do? Do I need a new oil pickup?
Thanks for the help.
ondarvr
Re: 95 Johnson 90HP OB Constant Warning Horn
Is this a "system check" unit, all of the lights in the tach? If so, they fail like that, the horn goes on and won't shut off. I have 2 of them, on one the horn won't shut of, and the other one the tach itself doesn't work but the horn does.
erebus
I don't have any warning lights in my tach, unless all the bulbs are blown, the horn used to just beep once when you turned the key to on.
erebus
Im hoping its just a bad connection somewhere.
tashasdaddy
constastant alarm, is overheat. or could be bad horn.
