Jerry Young
- May 12, 2009
- 10
I have a used motor and do not know the history of the motor. The temp alarm came on. I took off the cover and placed my hand all over the engine to feel for heat. There were no hot spots and the engine was just barely warm to the touch, but the alarm stayed on. After an hour, I cranked back up and the alarm was on immediately. The SELOC manual says that for the Mercury 70-115 HP motors that the temp switch is closed during normal operations and opens when hot. All the other HP motors operate just the opposite. Is this a misprint or wrong information, because my sensor operates as an open circuit when cold and short when hot. Has someone installed the wrong sensor? What is the correct part number for a 95' Mercury 115 HP motor? Can you run the motor without the thermostat and poppet valve?
