Re: 95 seadoo bombadire xp takes on water when moving
drive shaft seal and the exhaust hoses, if no luck there and you recently removed the pump from the ski, check the 2 o rings for the suction tubes that bail the boat, if they were left off water will get forced in to the tubes instead of siphoned out of the boat. also look at the welch plugs on the exhaust pipe those corrode and blast water in the hull, ride with the seat removed and look in the engine compartment, you will see water blasting out of a hole in the plugs
