Goodmanheelzfan
- May 15, 2018
- 5
Got this thing as a project, been sitting a while. Rebuilt carbs, replaced fuel lines and did the JB Weld repair on the wear ring and replaced the ride plate seal. Thing starts right up and gets on plane in seconds. Runs great for 20-30 minutes then dies and will not restart. Has fuel, spark and the compression is around 150 on all cylinders. Sits overnight and starts right back up. Any ideas? Checked thermostat and it's fine. Opened right at 130. I have the Clymer manual and the timing is at 30 btdc on full throttle when cranking. Rev limiter heating up or what should I check? Auto enricher closing in a couple minutes as well.
