!958 Mercury Problem
steelespike
Re: !958 Mercury Problem
MCHitman,<br /> Start with a ser. manual.You can get <br />reprint owners and ser.manuals at Grubbs Marine<br /> www.oldmercs.com.You also may be able to get some help at Johns Old Mercury Web Site at:<br />www.pfs-ware.com.<br />Youll probably need to do a good rebuild of the fuel system from tank to carbs.<br /> Your motor is rated at 40hp.<br /> Good luck.
Yepblaze
There's three or four bolts that hold the main magneto component to the magneto drive. If you can drop the "mag" and remove the points. Then lap the contacts very carefully with 600 grit wet or dry sandpaper then wipe them clean real good. Make sure they contact squarely when done with no irregularities in the contact surfaces. Reassemble and gap at .0008 to .0010 inch
ODDD1
yep, you got too many zeros in there...try .008" to .010"
