Re: 96 115 johnson (crossflow or the 60 degree)
The difference between a 60 degree and a 90 degree is the angle of the vee form by the connedting rods as the point toward the heads.<br /> A 90 degree motor is much wider across the back of the motor. A 60 degree would appear much narrower if it were setting next to a 90 degree motor.<br /> 90 degree are cross flow motors (they have domed top pistons which direct the flow of the fuel and air entering and exhusting the combustion chamber.<br /> The 60 degree motor is a loop charged motor and has flat top pistons.
