Greetings! Long time lurker, 1st time poster. Boat is a recently aquired '96 Rinker 180 with a 4.3 Merc LX Gen+
I've had it out approximately 10 times since purchase, and every time has started and ran beautifully, just touch the key and away she goes.
We ran up the river to the local swimming hole, and again, she started and ran flawless. Sat and played for a few hours, and when it was time to go, hit the key, fires and dies. When I say this, I mean the engine will fire, as long as the key is all the way in the start position, but when it fires and you let it go to the run position, the engine dies, as if you turned the key all the way off.
I was able to get home by jumping the battery + to coil+, and yes, I had normal oil pressure on the gauge. Ran like a million with the jumper.
I pulled the keyswitch itself, and ohm checked it, no problem there. Every fuse I found was good. I read in a few places that if there's no oil pressure (switch faulty) that it will cut power to the fuel pump. Will this also cut power to the coil? I would think that if the pump gets power it would pump more gas in and would run a bit longer.
Thanks in advance, you guys rock.
