96 5hp Merc with auto throttle grip shift
dickdale
Why does the motor lock in reverse every tenth shift to reverse? It seems that the problem is in the lower end and not in the upper linkage. It can be removed from reverse only by prying on the shift rod where it enters the lower end. All upper linkage seems to be functioning perfectly. This motor only has 10 hours.
