96 75hp force no fire
donnjax
my engine won't fire at all...suspect the rectifier (I know it's NOT the deadman switch). It just quit after a day on the water with no problems. Compression is 125 across all cylinders. Can anyone help?
donnjax
Re: 96 75hp force no fire
thanks TMD. Also, is there any simple continuity test for the trigger and/or stator?
The Marine Doctor
Yes...I will be working on that tonight. Should have something done by tomorrow.<br /><br />TMD
force01
it sounds like your stator went bad its a common<br />problem ,there is a redesigned stator available, test your old stator cranking , before you replace it thanks bret<br /><br />If you need further assistance please email me @ forcepower01@yahoo.com.
