'96 75HP Merc Starter Problem
Kx2ent
It seems as though the impeller that turns the flywheel doesn't stay ingaged long enough to kick over the engine properly. I'v had it worked on by my mechanic... he took it for a test run and everything was fine. Then a day later, hard time starting at the marina, then later across the bay... then on way back through the canal, she ran out of gas. I switched tanks, and she wouldn't start back up. Then today, I found out that a fellow boater in my marina was having same problem with same motor. have there been any recalls? Or, anyone here experiencing same or know how to fix it?
