coastalcruiser
- Aug 2, 2007
- 559
Normally your supposed to change oil in the drive end of season, But I decided to change the oil now since its used, no telling what your going to find. first thing is the drain screw, went to get a new O ring and the Volvo parts guy said there is only one but mine has two?
The pdf manual says to replace all O rings so have those on order.
It also says to use sealant on the drain and fill screw so I plan to use Merc Perfect seal. as the photo suggests the previous owner did not use any.
When draining the oil there was a very small amount of clear water.. Before i take the boat anywhere far, I want to make sure that it doesn't leak at all. right now is the time to do a pressure check so can I get a tester for that at Volvo or is there a universal tester at napa?
Anyway thanks for any thoughts you might have.
Rob
Rob
