96 bayliner jazz 120xr
cowboys5times
In the last week or so my jet boat has been running good at first and then i make a few sharp turns and it feels like its about to cut off. It will not go past 3500 rpm. But at 2000rpm it runs ok. we checked it and it was getting gas. can anyone help me. thanks.
kend301
Re: 96 bayliner jazz 120xr
First of all was your fuel flow pulsing or steady ?
Also remove the air box , go to WOT and check the carb butterflys to be sure they are wide open , a partially closed carb will produce the symptoms you described .
