I have purchased a 96 crownline. The trim continues to not work and the reset button has to be set constantly. It also seems to be pulling alot of amps when you attempt to use the trim...the gauges jump around and my radio cuts out and the GPS shuts down. It works long enough to usually raise or lower once then trips the reset switch. Is this an electrical issue, bad motor, relay or what. How do I test this?
