96 fast strike j150gled
BASRX71
i took m boat out the other day and it fell on its face.couldnt get it to stay running. so i posted on here and got some help. found out that the motor didnt have the corect spark plugs in it. so i changed them. i took it out for a bit today and it ws better. starts, idles with the high idle on. will move in forward gear barely and stalls out. no rpms. if i lift the high idle all the way up it will stay running about 1000 rpm and all the sudden it will jump up over 2000 but it spits and sputters.
how do you do the spark test, plug out hooked to wire? like in a car?
any help would be great thanks.
i have a multi meter but im not sure if its the same as a dva?
