Re: '96 Force 120 sat 5 years, feels locked up
You have heard of engines sitting for a long time. Every trashed engine ever sold was running when put into storage. And every boat sold goes 45 MPH. The check is in the mail, I'll respect you in the morning. etc.
OK! here is a relatively simple but long-winded example and explanation:
I once bought a Chrysler 12.9 that had been laying without the hood, in a field on its side for at least 5 years that I know of. I needed to cut out small trees growing through it in order to free it. After getting it home, I cleaned and set the points and --vroom-- she fired up first pull. However, that engine did not have water intrusion and had most likely been run enough to have a good coating of oil in the cylinders.
When I bought my Chrysler 140, it was locked up. The boat and engine was for sale in a marina and had only been sitting for a couple of months. When I got it home, I pulled the head. The bottom cylinder had a light coating of rust that was locking the piston. When I pulled the exhaust cover, I discovered that there was a break in the gasket and water was spraying into the bottom cylinder. If the engine was run every week, the water would not have time to form enough rust to jam the piston. HOWEVER: After sitting for a couple of months, there was sufficient rust to stop the engine from turning over.
In this case I was lucky. The rust was light and tight, not flaking, so I was able to hone it out and use the same piston and rings.
Now, My buddy takes jammed engines and oils the cylinders. Sometimes this frees them BUT--although the engine is free and now runs, he has not examined the inside. Initially there will be some abrasive material left inside, and service life of the engine is reduced. Obviously I don't agree with his half fast methods.
You may be able to free the engine by oiling the cylinders but you would be much better off to at least remove the head and see exactly what the problem is---that is, if you intend to keep the engine.
If you take the time to do it right the first time you will avoid further problems later on.
