96' force 120 trim leak down
PLankford
Trim leaks down slowly. Has been working great. Now slowly leaks down. Fluid is perfect. Low hours.<br /><br />Where should I start? <br /><br />Thank you<br /><br />pwlankford@netzero.net
clanton
Re: 96' force 120 trim leak down
Check seals on manual release valve and insure valve is tight. Most likely cause of leak down on Force engines is check valve seals. Look at Clymer<br />ISBN 0-89287-732-4, page 537/537 figure 19/20, two types your engine. Page 538 has trouble shooting for leak down.
