ericspainter
- Nov 23, 2010
- 25
Ok let me thank you for your help first off.My questions are were does the water come out to let you no the water pump is working.Every outher outboard i have had has a little hole on the cowling it comes out of and this one doesnt.A little water comes out the back exhoust holes but very little.Is that were it is suppost to come out?I can see a little hole in middle of this but not sure if it is a exoust hole or not.I thought exhoust came out prop.
Ok i orderd a water pump repair kit and i need to no how to remove the lower unit .i now the shaft is splined but how do i get the shifter linkage broke loose.Any tips or tricks i need to now for my first lower unit removal.
I just got this boat and it idles good but i tried to take it out and it woulded go like it was boged down.I put my hand over carb while on water and in gear and it bout threw me out of the boat lol.I removed the carb to find it had had gas in it from five years off setting.I also orded new parts for that but i can handle the card just need help on the water and lower unit removal.thanks for your help ,Eric
