Check the exhaust cover gaskets and the gasket under the block against the midleg.
This is not so uncommon on these engines.
I do not think there is a problem with the head gasket, if you would have some other problems too.
You can check by running the engine without the hood, if it does not stop with the hood off then the problem is not in the head gasket.
