High Beams, Hazard and Tail lamps work fine. Low Beams (both) are out.<br /><br />Checked all fuses in the dash fuse box. Tested OK.<br /><br />Checked for continuity on the Headlamp Relay in the engine compartment. Also swapped with another identical relay to test. Tested OK.<br /><br />What am I missing here? I have a hard time believing both head lamps need to be replaced at the same time. <br /><br />Suggestions?<br /><br />Thanks,<br />Brian
