1996 Mariner Magnum 3, 150hp OB, 0G383790: Was hard to start when cold, and the heads seemed hot. I installed the new water pump kit, and whoever installed it last used the wrong gaskets in the wrong places, as well as did'nt remove all the parts of a previous failed impellar. I cleaned all that out, and put all new everything in. I installed a new Fuel pump kit, no more gas dripping everywhere. It starts easier, and pees almost right away now.
Heres the deal, the heads are cooler now.....but still seem a little hot. I can touch them for about 2 or 3 seconds then I have to pull my hand away. Pee stream is better, but then I removed the t-stats and re-installed the covers and now it pees like a race horse, and heads are WAY cooler. The t-stats did'nt seem to look to bad, and they open freely. Question is, how hot should those heads be with the stats in? Is the 2 or 3 second rule ok? Or should I be able to hold my hand on it for a long period of time like I can without the stats?
