I have a 1996 Mariner Magnum 3 outboard, 0G383790, 150hp outboard. I did a compression test, and plan to replace the water pump this week. All 6 cylinders were 110 psi even. Heres the following issues:
#1: Kinda rough idle, and VERY hard to start after it sits for a little while. Heres what I noticed. On the Fuel Pump, there is some gas/oil mix on the outer plate, and the vac hose running to the outer plate don't seem to be seated well, as well as some gas oil mix dripping from the "dry" side of the outer plate gasket. If im correct, gas should not be in this section of the assembly right? It should be flowing through the middle only right? If so then I guess I need to replace the gaskets and diaphrams, and maybe that will correct that issue?
#2: Motor don't pee well, sometimes won't pee at idle, but ALOT of steam comes out the pee hole. Motor feels hot, pees like a race horse at full throttle. Alarm has never gone off and it does beep when the key is turned on. I assume the t-stats are opening due to the amount of steam, so should I just replace the impellar, or do the impellar and poppet valves? I just got it, everything seems well...runs very well pushes a 19' Keywest at 60mph. I just need to correct these issues. What else should I look for?
Also, when I drop the lower unit, do I need to disconnect the shift shaft somewhere first, or does it just slids part when the lower unit is removed?
THANKS IN ADVANCE!!
THANKS IN ADVANCE!!
