I was out in the lake this weekend, and with no notice or alarm the engine just stopped, checking further, the starter would not turn over the engine. Oil resivoir was full. A mechanic pulled the oil pump cover and linkage and found ground up plastic/fiber inside. Is this a known problem? Any recalls? What has likely happened to my engine? Should I rebuild? or get a new power head? Can I bypass the oil injection and go back to at 50:1 mix in the gas? Thanks.
