'96 Sea Ray Express Cruiser "Rough Idle"
bbartos1
:confused: <br />Any suggestions on why my '96 Sea Ray Express Cruiser seems to have rough idle and why I can't find a sweet spot for the wake speed (too slow almost stalls) or too fast (creates a wake). Is there a a "SeaRay-ese" translation that a mechanic can understand?
MooseHootie
Re: '96 Sea Ray Express Cruiser "Rough Idle"
What have you tried to do to correct your problem so far ?
I Guess you Should start with the Basics......<br />A Tune-Up......
bbartos1
Tune Up? Been there done that...The easiset thing would have been to advance the timing...<br />Note:<br />I had an unrelated pre-existing "vapor lock" problem in hot weather where after 5-years Searay finally sent me a TSB that cautioned against using 87 octane gas (usually loaded with 10% of methanol)bad stuff for a carburated engine and compelling reason for EFI.
Well,<br />It would appear that Something Didn't get done Right............<br />If it Had, It Wouldn't Idle Rough...........<br /><br />How about a Compression,+ Leak-down Test..........
