'96 Sunbird Spirit 170, 88hp Evinrude, Prop slipping
wcheney
First time I've run this boat with four adults (about 850 lbs worth, Usually run two adults and two kids). When water started getting choppy the prop started slipping before I could get on step. Motor appears to be mounted correctly. Prop is a 15.5" dia x 15" pitch Rubex 3. I'm thinking I may want to switch to a four blade prop. When running with me alone and about 10 gallons of fuel (1/2 tank) rpms max out at about 5100 and gives me a speed of about 34 mph (gps) on moderately calm water. I was thinking of going to a Rubex 4, 15 x 13 but I'm wondering if dropping 2" of pitch is too much of a drop? Any thoughts?
steelespike
Are you sure those are 15.5" diameter?Perhaps 13.5? I couldn't find props in any pitch near 15 only 14" was the max I found.
I think your tach is reading low 88hp with 2.00 gear ratio" 5100" @34 gets 6% slip thats very low and unlikely.
If we substitute a more reasonable number 12% we get 5440. Tachs are always suspect
Is the hole shot strong with a light load ?You should confirm your tach before any changes.Maybe borrow a shop tach.
Or get a induction tach.
wcheney
You are absolutely right, 13.5" not 15.5" diameter. Damn auto-correct! ;)
I'll see if my strobe tach still works.
wcheney
I had the opportunity to test rpm with an external tach today. Boat tach at 2000 rpm external tach at 1900 (+/- 20 rpm). Will try next time it's on water at higher rpm next week to see if I get similar results.
steelespike
A light wot run for rpm and gps speed.A 4 blade should help.The test will help figure what size,.
