hubcitymn1
- May 24, 2003
- 3
Yesterday, as I was preparing to head to the lake, I used my power tilt/trim to raise my '96 Suzuki DT75 in order to put the transom saver in place, then tilted it down onto the saver for a good, tight fit. Went tothe store and filled it with gas. When I got home, I thought I'd run it a little while just for safety's sake before leaving for the lake. When I tilted up to remove the "saver"..it went up fine, but this time would not tilt down. It makes an audible click when I press the switch down, but goes nowhere. Still works fine going up. This does the same thing whether I use the switch at the engine or up front at the control lever. What could be my problem?
