Cricket Too
- May 14, 2003
- 1,732
I've noticed lately that when I start my engine when cold, it has a noticable miss every now and then, not steady, until it warms up.
It will do it while idling at the dock and then sometimes on the way down the canal, but once I get out and open it up, it takes right off and has no problem and has no miss after that.
It has also started to sneeze slightly when first started cold, and sometimes will sneeze hard and stall right out, a pretty violent stall, after just starting cold. Once re-started it will run fine, unless of course it decides to have that random miss at idle.
My voltage has started creeping up past 15V while cruising too, at about anywhere from 4200-4400 RPM. It will hold steady at 15V and then creep up to close to 16V and then come back down, randomly. Not sure if this is completely unrelated or not.
I am going to pull the carbs and clean and rebuild them over the winter, but the boat is in the water right and will be for another month or so.
Any idea of what the random miss could be? It doesn't do it all the time.
Thanks.
Thanks.
