G
Guest
Guest
Just put my prop lower unit on last week (took off my jet) and when I ran the boat at WOT (5100 rpm) the boat/side console was shaking violently in fairly calm water.
I did adjust the trim tab on the outboard which did reduce it some but I still have to probably adjust it a little more.
Looking at this pic, does my motor position (tilt) w/ manual trim look about right for a tunnel hull?
I just had the prop re-surfaced/re-balanced by a guy who does good work.
