97 200hp. merc
jimmie22
my problem is the engine just spins over but doesnt fire, i have spark,compression,fuel pressure up to the pump, i turned the key over and look at the injectors to see if i had spray<br />and i had none but if i turned the key over and<br />pushed the needle in on the injector fuel sprayed<br />any ideas why the injectors are not spraying fuel<br />on their on into the engine
The Marine Doctor
Re: 97 200hp. merc
When you are turning the engine over are you getting any kind of voltage to them?<br /><br />By your little expiriment we know that you have the pressure.<br /><br />You are not advancing the throttle lever are you?<br /><br />TMD
jimmie22
Re: 97 200hp. merc
how would i checked that because i dont hve the manual for it is there a way you could tell me and if you know the specs it is supposed to be at
The Marine Doctor
Re: 97 200hp. merc
I do not have the spec's in front of me...It should be DC current. So a voltmeter would work.<br /><br />TMD
