BoatinJoe13
- May 9, 2013
- 10
I recently picked up a boat with 5.7 GL PLKD engine. Initially it was running but only for a short time and any throttle would kill the engine. The previous owner said it sat for 2 years and he was sure it was just bad gas, as did I. It is a Holley 2300 2V carb.
I ordered a repair kit and took it apart. Several metering holes were fairly plugged. Put back together (took my time and it appears to have gas flowing fine, accelerator pump will squirt gas with full throttle. No way to check float level on these carbs that I know of). Problem is I can't get it to even run for a little bit now.
I've looked at many threads here. Initially I wondered if the kill switch was an issue. I finally removed that temporarily. With it gone and Key On I get 11 or so volts at the coil (checking on engine ground). I do get spark when tested with a spare plug on the block. Also after cranking a while the plugs do have gas on them. Put in new plugs to be safe. Checked compression and all 8 were 165-170.
I even tried to remove the grey wire from my tach as someone pointed that out. Any help or pointers would be greatly appreciated.
