bullcity101
- Mar 30, 2012
- 73
All,
Thank you in advance for you advise.
I am at a place where I do not know where to go from here.
I went out to start the outboard after a few weeks and noticed a rough low idle, my first instinck was bad fuel. I replaced the fuel and still a no go. I went to rev the engine (on flusher so only what the neutral limiter would let me) and it would bog down and die if I didn't bring it back to idle. While running, I went back to the plugs and pulled the top plug boot and there was no change in how it was running. Put that back on, pulled the bottom and it quit. Which lead me to believe its only running on the bottom cylinder. I pulled the carbs, cleaned the jets, adjusted the floats. I sprayed and blasted with compressed air. Put them back on and still the same sysptoms. I then checked fuel flow by pulling the line attached to the carb while running and it has good pressure. I then went to square one and checked compression, 118 on the bottom and 120 on the top.
I know it has spark, I know it has compression. So I even sprayed fuel in the top carb while it was running and it had no change.
Fuel, air and spark...I DONT GET IT.
Also, I had noticed that the water that escapes from the exhust is brownish...Does that have any meaning???? '
Please HELP!!!!
John
Please HELP!!!!
John
