'97 Force 120 Prop Shaft
mgdad0724
Needing some input from some seasoned vets out there... I have a '97 Force 120 and I think I spun the prop, but in the process of my investigation, I pulled the prop shaft to make sure the gears in the lower unit were OK. I have found the exploded views online, but for what I am needing, they are not very helpful. As I removed the prop shaft, the cam follower came out of the shaft as well as the 3 ball bearings. When assembled properly, does the follower just rest on the 3 ball bearings or am I missing something? I just want to make sure I have everything back where it belongs. Thanks in advance for your help!
